1989 Cadillac Deville ECM Control Unit
110,000 MILES • V8 • FWD • AUTOMATIC
LARKIN600
The air condition nor the heat comes on in my Coupe DeVille Cadillac. On the Dash all of the digital readouts are out except the speedometer etc. The only thing I see is what appears to be half of a 2, the lower part of the number 2. Does this mean the ECM module has gone bad?
Oct 27, 2008 at 3:19 AM
IMPALASS
  • 3,112 POSTS
Hello Based off of what you have said and I am understanding what you said, there seems to be a Technical Service Bulleting out on this. I have attached it for your review. There may be a loss of power or ground. Bulletin .No. T-91-38 File in Group 8 Number 130 Corp. Ref. No. 018126 Date Jan. 1991 SUBJECT: VACUUM FLUORESCENCE DISPLAYS FLICKER OR GO BLANK MODELS AFFECTED: 1985-1991 DE VILLES AND FLEETWOODS Some 1985-1991 DeVilles and Fleetwoods may experience a condition of vacuum florescence displays flickering or going blank and the Electronic Climate Control (ECC) blower going off. This may be the result of a loss of power or ground to the Body Control Module (BCM) or an internal problem with the Digital Instrument Cluster (DIC), ECC, Fuel Data Panel (FDP), or ECC power module/blower. Within the BCM there is a regulator which provides 16 volts for the Vacuum Fluorescence (VF) displays of the DIC, FDP, and ECC. This regulator also provides the variable voltage input to the ECC power module for blower speed control.
https://images.2carpros.com/forum/automotive_pictures/248015_42219655_1.jpg
To diagnose and repair these conditions use the following trouble tree.
Oct 28, 2008 at 2:56 AM
