1989 Cadillac Deville Backfiring/very rough idle.
78,000 MILES • V8 • FWD • AUTOMATIC
CADDYJER
I own an 89 Deville. I have replaced the fuel pump, strainer, filter. The fuel pressure regulator, distributor cap, rotor, pickup coil, all spark plugs and wires. Battery is new, alternator has been tested and passed. Egr valve moves freely. It will run fine for about 15-20 minutes then start acting like its starving for fuel. It will sputter then surge and begin to backfire. I have read many of your messages to others with similar problems. The only things left I can think of are the MAP sensor and the ignition control module in the distributor. When I do the computer diagnostic check the codes I get are E21 and E 28. I'm just at the point where I'm throwing money at it. If you have any suggestions or advice on how to proceed from here I would be very greatful.
Feb 28, 2008 at 12:44 AM
MERLIN2021
  • 17,250 POSTS
Well the E 21= shrted TPS circuit
28=open 3rd or 4th gear circuit.
or quad driver #3 circuit fault.
Locate the black and blk/pink and dark blue wires at the tps, with key on engine off backprobe with a voltmeter, at closed position you should have .5 volt or less, at wide open it should be about 4.5 volts, if not unplug and test the two wires for continuity, should be none...if tps fails replace it.
Feb 28, 2008 at 7:11 AM
