1988 Cadillac Deville Wiper arm
20,120 MILES • V8 • 2WD • AUTOMATIC
GREG ALLEN
How do you remove the passenger side wiper arm does it require a special tool. 1988 Cadillac Deville
Nov 27, 2009 at 12:04 PM
FACTORYJACK
  • 4,159 POSTS
Is there a holddown nut on the pivot(under a cap?). If not, there is a little slide lock, evidenced by a little tab sticking up on one side or the other. Lift the arm about midway between as high as it goes, and the contact of the windshield, and this tab should slide outward a bit, and the arm should come off. If it has a pivot nut, remove and work it a bit, and it will come off the splines.
Nov 27, 2009 at 1:55 PM
