1987 Cadillac Deville Water in carburetor
1987 CADILLAC DEVILLE
187,000 MILES • V8 • 2WD • AUTOMATIC
TRMILLER1
I have been searching all evening in hopes someone could answer a question for me. Suddenly my car has been losing coolant but was unable to locate it. It would cut out badly but no one could tell me why. I looked for leaks everywhere. Tonight when I came home I popped the hood as I saw some steam and saw coolant on top of the radiator coming out of the breather. I took the breather cover off and there was coolant all inside. I have no idea where this is coming from. I don't know if this is caused by a bad thermostat or what. It looks like it is coming from a hose connected to the breather on the back side. If someone could lead me in the right direction I would be ever so grateful.
Dec 6, 2008 at 3:06 PM
DOCFIXIT
  • 18,828 POSTS
Most likely an intake gasket failure coolant flows through intake to heat up and cool . Look at oil stick look ,like chocolate malt? then coolant in oil if not leak is into intake and is burned up in combustion.
Dec 7, 2008 at 6:14 AM
