1983 Cadillac Deville alternator problems
89,000 MILES • V8 • 2WD • AUTOMATIC
BALD_DRAGON721
this is the 3rd alter. in 1 1/2 weeks...the battery is new. the voltage was 14.5 before, then i noticed that the engine compartment light wasnt as bright. rechecked the alter. and it showed 12 volts. after i turned the heat and the headlights on. the onboard diagnostic shows code 16. noone seems to know what the problem is...there are no fusible links from the alternator, no fuses blown and an ammeter test was done and showed nothing. neg. ground wires were cleaned and checked.
Dec 19, 2007 at 10:23 AM
BGLOCC
Do you have an aftermarket audio system in it?
Dec 20, 2007 at 3:49 AM
BALD_DRAGON721
[quote:c3cd8d1aa0="bglocc"]Do you have an aftermarket audio system in it?[/quote:c3cd8d1aa0]
no everything in the car is still factory. the xmission is the only thing that has been replaced because it sat for a while....however.... it was running fine before these problems happened....i just now replaced the connector that plugs into the alternator, started the car...everything ran 14.5. I turned the headlights and the defrost on (i need those in the morning for work) rechecked the voltage again and it dropped to around 10.5-11 volts.
Dec 20, 2007 at 8:55 AM
BUZZSAW
  • 1,198 POSTS
[quote:bc6440a9bd="bald_dragon721"][quote:bc6440a9bd="bglocc"]Do you have an aftermarket audio system in it?[/quote:bc6440a9bd]
no everything in the car is still factory. the xmission is the only thing that has been replaced because it sat for a while....however.... it was running fine before these problems happened....i just now replaced the connector that plugs into the alternator, started the car...everything ran 14.5. I turned the headlights and the defrost on (i need those in the morning for work) rechecked the voltage again and it dropped to around 10.5-11 volts.[/quote:bc6440a9bd]
where did you buy the parts at?
Dec 20, 2007 at 9:17 AM
BALD_DRAGON721
[quote:f64333f2e4="Buzzsaw"][quote:f64333f2e4="bald_dragon721"][quote:f64333f2e4="bglocc"]Do you have an aftermarket audio system in it?[/quote:f64333f2e4]
no everything in the car is still factory. the xmission is the only thing that has been replaced because it sat for a while....however.... it was running fine before these problems happened....i just now replaced the connector that plugs into the alternator, started the car...everything ran 14.5. I turned the headlights and the defrost on (i need those in the morning for work) rechecked the voltage again and it dropped to around 10.5-11 volts.[/quote:f64333f2e4]
where did you buy the parts at?[/quote:f64333f2e4]
i got all the parts from autozone. the alternators have the warranty so ive been takin them back thinking that i keep getting bad ones
Dec 20, 2007 at 10:14 AM
BUZZSAW
  • 1,198 POSTS
[quote:bba48eac08="bald_dragon721"][quote:bba48eac08="Buzzsaw"][quote:bba48eac08="bald_dragon721"][quote:bba48eac08="bglocc"]Do you have an aftermarket audio system in it?[/quote:bba48eac08]
no everything in the car is still factory. the xmission is the only thing that has been replaced because it sat for a while....however.... it was running fine before these problems happened....i just now replaced the connector that plugs into the alternator, started the car...everything ran 14.5. I turned the headlights and the defrost on (i need those in the morning for work) rechecked the voltage again and it dropped to around 10.5-11 volts.[/quote:bba48eac08]
where did you buy the parts at?[/quote:bba48eac08]
i got all the parts from autozone. the alternators have the warranty so ive been takin them back thinking that i keep getting bad ones[/quote:bba48eac08]
there is your problem, autozone sucks for parts, go buy one from napa or the dealer, autozone is only good for fluids and such, you only get what you pay for, now your doing it a 4th time, sorry to say
Dec 20, 2007 at 2:50 PM
