1970 Cadillac Deville bent pushrod , lifter?
111,000 MILES • V8 • 2WD • AUTOMATIC
KBM1961
1970 / 472 cYlinder 5, 1 PUSH ROD BENT CAR SITIN FOR 2 YEARS REPLACEDD PUSH ROD BENT AGAIN, LIFTER BAD? CAN I RUN ENGINE WITH OUT THAT ONE PUSH ROD TO GET OIL FLOWING TO MAYBE FREE UP LIFTER
Feb 17, 2008 at 6:36 PM
MERLIN2021
  • 17,250 POSTS
If it froze this bad...it is probably a wise idea to dissasemble and clean the rust out...
Feb 17, 2008 at 11:19 PM
ED ARMES
  • 129 POSTS
Problem may not be with the lifter. They usually will not stick up in the bore.
I lean towards a stuck valve possibly. Alot less lubrication in this area and most likely to stick. As lifter comes up the push rod meets an imovable object ( valve ). "It Bends". Seen this before in other engines big and small.
What do you think Merlin 2021.
Mar 8, 2008 at 3:36 PM
MERLIN2021
  • 17,250 POSTS
Like I said, tear down time...
Mar 9, 2008 at 12:10 AM
BUZZSAW
  • 1,198 POSTS
[quote:37e2e55252="merlin2021"]If it froze this bad...it is probably a wise idea to dissasemble and clean the rust out...[/quote:37e2e55252]
if unleaded gas was being used its probally the valve thats stuck, take the valve cover off and rocker off and hit it with a hammer
Mar 10, 2008 at 6:23 AM
