differential worn out?
42,000 MILES • 6 CYL • 2WD • AUTOMATIC
RMINDS
On this car, if the differential is worn out.. Will it create excessive tire wear ???
I really need to know ..... PLEASE ?
Feb 2, 2009 at 10:56 AM
FACTORYJACK
  • 4,159 POSTS
I can't see a worn differential contributing to excessive tire wear. Maybe in severe conditions where the limited slip clutch plates were stuck and you were doing continuous tight figure eights.
Feb 2, 2009 at 12:41 PM
MEGA4949
There is a howling noise while I am driving only. Its most constant when I am doing about 45 MPH. The noise sound changes in loudness and HUMMING when I increase and decrease speed. I think it is coming from the rear differential. Am I right, and what would the repair cost if needed. Thanks michael
Jun 1, 2020 at 10:35 AM (Merged)
MERLIN2021
  • 17,250 POSTS
It's either a axle bearing or carrier bearg, or pinion, and has to be further diagnosed b4 the how much can be answered!
SEANROB1
when i turn my car on i proceed to put it in drive gear it will not move unless i turn car off step on brake then put the key back in the ingntion turn car on then it moves into drive gear. what could that be
FACTORYJACK
  • 4,159 POSTS
Are you stepping on the brake the first time around, I would assume you are, but it does not say so. There may be an issue with the shift lock solenoid, or the signal that it needs.
SCOTT ULMER
On my 2005 cts I have a whing in my differential I had it for awhile. My understanding cadillac had this problem for awhile. Is there anything that I can do to make the whing to go away besides replacing the differential? Thank you.
Jun 1, 2020 at 10:36 AM (Merged)
  • 75,988 POSTS
It depends on what is damaged-you just have to inspect it to determine if it needs replacemebt
CADIEMAN
  • 3,544 POSTS
check the trans filter it maybe clogged.
TONY102
This is a CTS-V , 6 speed. Will not go into gear unless engine is shut off. What would approximate cost of repair be? Also what is approximate cost to repair rear differential which is "cracked" and makes a thumping noise upon acceleration.
HMAC300
  • 48,601 POSTS
sounds like a clutch is bad, you'll have to check locally although i'd say you are looking at close to $4000 for clutch and maybe a rear end housing. you might check and see if you can get the rear end used.
HOTROCK
Noise from rear end. tires and hub bearings have been check. what type of charges to exspect with differential repair?
FACTORYJACK
  • 4,159 POSTS
All depends on the severity of damage. It could get easily into 1000 to 2000 or more. Alldata doesn't show any labor times.
