2005 Cadillac CTS RE: Engine Performance
36,000 MILES • 6 CYL • 2WD • AUTOMATIC
JAMONIT
My car stalls when I am driving between 40-60mph. Something in the engine is rattling between 20-30mph. The engine light flashed several times while driving on the highway at about 60mph. What is this?? I am taking it to the dealer on Monday, 1/26/09, but do not want to be ripped off?? I tried fuel injector cleaner with some improvement. Please advice.
Jan 23, 2009 at 12:10 PM
BRIAN 1
  • 1,030 POSTS
have it scanned for codes,you can go to autozone and have it scanned for free and post back with the codes,also I would check with the dealer I think cadillac warranty is 5/40,000. this might still be under warranty.post back with any other questions.
Jan 23, 2009 at 12:17 PM
FACTORYJACK
  • 4,159 POSTS
You might check your oil level. Low oil causes some problems with the Variable Valve timing. Have not seen a stall from it, but the engine noise is a strong possibility. The check engine light flashes to warn you of a catalyst damaging misfire, which also can be caused by a valve timing issue. I have seen vehicles up to 3.5 quarts low on oil that is just due to consumption. Cadillac warranty is 4yr/50k, it will depend on your vehicles in-service date.
Jan 29, 2009 at 3:16 PM
JAMONIT
I took the 2005 Cadillac CTS to the dealer.
Report from Cadillac Dealer Repair- Under Warranty-
Cause: Vehicle was in need of oil change, oil level very low drying outlvetrain causing a misfire
code- 36462
bad cell in battery- code 36462 N0110
gas cap not sealing properly- code 36462 J9994
I was charged $200 for a power oil flush and change with high performance oil.
The service advisor told me not to rely on the oil indicator life. I was told when I bought the car to wait until the oil indicator life reaches less than 20%, which was usually around 8000 miles. Any advice.
Is my car ruined from this??
Mar 7, 2009 at 5:44 AM
FACTORYJACK
  • 4,159 POSTS
If there is no more noise, and running fine, I think it is safe to say your fine. I think the $200 oil change was unnecessary, you were simply just low on oil. Oil change intervals have become a gray area, some still recommend the 3mo/3k mile change. Your CTS calls for Mobil 1 synthetic that can go 10k between oil changes, and the oil life monitor does the job very well however, the oil level still needs checked. Normal oil consumption can be 1 to 1.5 quarts in 1000 miles depending on driving habits.
Mar 8, 2009 at 4:35 AM
