2005 Cadillac CTS radiator
56,000 MILES • 6 CYL • AWD • AUTOMATIC
KRO98002
Is there a special tool used to take off the hose around the line to go to the transmission? What tools are needed to change a radiator in this make and model?
Jan 15, 2010 at 9:37 AM
FACTORYJACK
  • 4,159 POSTS
There is a special tool to disconnect the transmission cooler lines from the radiator. It is a thin wall type of removal tool that slides on the line, disengaging the retaining ring. I don't know of any aftermarket tools, kent-moore makes them for dealer use. If you need the kent-moore number, I can research it and get it to you.
Jan 15, 2010 at 2:25 PM
KRO98002
do you happen to know the number for that tool?
Jan 16, 2010 at 4:49 AM
FACTORYJACK
  • 4,159 POSTS
Yes, it is J-4482, Kent-Moore is the manufacturer
Jan 17, 2010 at 2:50 AM
