2005 Cadillac CTS navigation system
40,000 MILES • 6 CYL • AWD • AUTOMATIC
FRANK H
I recently put a factory navigation system in at a cadilac dealer and they can't get the system to operate properly. They say that since the car didn't come with it that's why it doesn't work. I don't believe that to be the case. The unit all seems to fuction well, just that it is not picking up the location of the car and the map and car doesn't move on the screen. The antenna is placed in the dash where it is suppose to be and every other feature works. Is there any kind of programing or other device that may be missing to make it work.
*note This car did not come with the unit from the factory. It was installed afterwards.
Any help would be greatly appreciated.
email fhouswerth1225@comcast.net
May 6, 2008 at 3:52 PM
BUZZSAW
  • 1,198 POSTS
[quote:9f065af4f4="frank h"]Interior problem
2005 Cadillac CTS 6 cyl All Wheel Drive Automatic 40000 miles
I recently put a factory navigation system in at a cadillac dealer and they can't get the system to operate properly. They say that since the car didn't come with it that's why it doesn't work. I don't believe that to be the case. The unit all seems to function well, just that it is not picking up the location of the car and the map and car doesn't move on the screen. The antenna is placed in the dash where it is suppose to be and every other feature works. Is there any kind of programing or other device that may be missing to make it work.
email fhouswerth1225@comcast.net[/quote:9f065af4f4]
take it to the dealer its still under warranty
May 7, 2008 at 5:31 AM
FRANK H
To: Buzzsaw,
Your answer didn't help.They sent in the unit and recieved another one and it still does the same thing.Don't know if there is something missing here electrically or what. Since the car didn't come equipped from the factory with the unit, I don't know if the antenna on the roof of the car has anything to do with it or not. The navigation antenna that came with the unit is located under the dash pad in its proper location.
May 9, 2008 at 12:25 AM
BMRFIXIT
  • 19,053 POSTS
We had the same issue on another GM product
problem was solved by relocating the GPS antenna
temporary place the antenna out of the car for the test
hope that will help
May 9, 2008 at 11:00 PM
