2005 Cadillac CTS Car Moves When In Park
20,000 MILES • 6 CYL • 4WD • AUTOMATIC
JAYBOY08
My car was previously in an accident from a head on collission with the previous owner. I bought the car and had it repaired and rebuilt. Everything works fine, it drives fine. However, the only problem I have is that when the car is parked on a slight incline or decline such as a small hill, it does remain still. The car either moves backward or forward depending on how its tilted. It is not able to hold still while in park on an incline but there are no issues on a level surface. Do you know what the problem may be and how needs to be done to correct it?
Jan 15, 2010 at 4:38 AM
FACTORYJACK
  • 4,159 POSTS
You could have bent, or misadjusted shift linkage. On the rh side(passenger) of the transmission is the linkage. There is a 10mm nut that controls the adjustment. You might try disconnecting and see if you can manually place it into park(rear wheels raised and park brake off). If it engages in park, reconnect the rod and tighten the nut. If it is beyond the adjustment range, the rod may be bent.
Jan 15, 2010 at 2:30 PM
