2005 Cadillac CTS car loosing oil
EBANKSK
  • 2005 CADILLAC CTS
  • 6 CYL
  • FWD
  • 102,000 MILES
My car is loosing oil slowly. I checked under the car, replaced the spark plugs and I cannot find where the oil is going. There is no smell of fumes; only after about two months or so the dip stick gets below the first hole on the dipstick. Any suggestions?
Saturday, August 22nd, 2009 AT 4:02 PM
MIKE.SHRUM
  • 43 POSTS
How close in mileage are you to oil change. When you pulled plugs what did they look like.
Saturday, August 22nd, 2009 AT 5:31 PM
If there's no leak externally-check the radiator for oil, not there -could be burning in the combustion chamber.
Saturday, August 22nd, 2009 AT 5:32 PM
FACTORYJACK
  • 4,159 POSTS
You can monitor consumption, the acceptable rate is around 1 quart in 2000 miles. To get a better grasp on if it is irregular, start a consumption test by placing it at a known level, and checking it periodically, say every 1000 miles. Consumption can vary with driving habits.
Thursday, August 27th, 2009 AT 10:28 PM
