2005 Cadillac CTS
40,000 MILES • 6 CYL • 2WD • AUTOMATIC
TONYCTS
The stoplights go on with the lights, but doesn't get brighter when the stop pedal is pressed
Aug 17, 2009 at 1:37 PM
FACTORYJACK
  • 4,159 POSTS
Does the high mount work, if so your switch is good. I would start with replacing both uppermost rear stop/tail bulbs. If the high mount don't work when the pedal is depressed, key on, you have other possibilities.
Aug 17, 2009 at 4:47 PM
