when i put gas it does not wont to turn on unless i give some gas. and after i its does turn on it not give me problems
Sep 21, 2009 at 8:42 AM
ERNEST CLARK
✓Experienced Mechanic
I would like to help you with your problem, but you'll have to explain it a little better.
Feb 28, 2010 at 3:38 PM
FSCHREIER
MEMBER
I had the same problem on my '06 CTS. After fueling, it was very hard to get it to start. Once it started however it would start right up. Here is what solved my problem: Replaced FUEL TANK PRESSURE SENSOR and EVAP PURGE VALVE.
