2003 Cadillac CTS TRUNK
2003 CADILLAC CTS
75,000 MILES • 6 CYL • 2WD • AUTOMATIC
CARLOS17
  • 6 POSTS
my trunk would not open, after checking fuses, relay, and rear integreaded module they all work, my question is, if the relay is closing and opening when operating with remote control or release button on the door where does the signal go from relay, direct to trunk latch or that it hit something else before getting there, trying to figure out if i got a broken wire some where or some other part gone bad, thanks for your time
Jan 11, 2010 at 10:32 AM
FACTORYJACK
  • 4,159 POSTS
You can check for a signal at the release solenoid with a test light. If the relay is sending, it is power on tan/white pin A, and it is grounded on pin B(g402). It is direct from the relay to the actuator.
Jan 11, 2010 at 5:57 PM
CARLOS17
  • 6 POSTS
I do not have voltage
Jan 11, 2010 at 11:42 PM
CARLOS17
  • 6 POSTS
Is the relay sending signal to latch or actuator?
Jan 11, 2010 at 11:48 PM
FACTORYJACK
  • 4,159 POSTS
In this case, the latch and actuator are the same. Like I say, from the relay, power goes to Pin A of the latch(actuator) on a tan/white wire, Pin B is a black wire that grounds. You can check it by bridging Pins A and B with a test light. If you have no light, substitute pin B with a good chassis ground. If you still have no light, then it is almost certain you have no power. Often times, there are other relays in the same panel that are the same. Try swapping it with another relay in the panel, and see if it works.
Jan 12, 2010 at 12:29 AM
CARLOS17
  • 6 POSTS
Yes actualy there are three relay all the same and I swapthem already but nothing I can here the same relay opening and closing like before
Jan 12, 2010 at 1:05 AM
FACTORYJACK
  • 4,159 POSTS
You could have an issue with the fuse block, or an open circuit 56 which is the tan/white wire that is direct from relay to actuator Pin A. The schematic is calling it r33 at the relay, I don't know how they are labeled, or if the are. With the actuator disconnected, and the relay out, you can measure resistance of that circuit by probing Pin A at actuator, and probing the relay terminals. If you don't have continuity on any, it may be open. Or you can go to the back of the fuse block, and determine which is the correct terminal. The control side, and the switch side of the relay share the same power feed which is jointly connected within the fuse block. Check with a test light that there is two powers at the relay pins r31 and r32. If there is not two powers, you could have an issue with the fuse block.
Jan 12, 2010 at 2:48 AM
CARLOS17
  • 6 POSTS
Thanks I'm going to do that, check resistance from pin A at the actuator and pin 33 ay the relay , thanks for your help!
Jan 12, 2010 at 3:16 AM
CARLOS17
  • 6 POSTS
Just want to tell you guys thanks for your help found a broken wire#56 under trunk liner thanks again
Jan 12, 2010 at 7:27 AM
