2003 Cadillac CTS rear wheel bearings
107,000 MILES • 6 CYL • 2WD • AUTOMATIC
RIGBYJ
how do I change the rear wheel bearings
Jun 9, 2010 at 11:16 AM
FACTORYJACK
  • 4,159 POSTS
You have to get the rear spindle loose so you can remove the axle. Remove and hang the caliper, remove the rotor, disconnect the shock, the tie rod, and the lower control arm. This should allow the spindle to move enough to get the axle out. The bearing/hub is held with three(or maybe four) bolts. You are going to need a support stand and a jack to facilitate this in both disassembly and reassembly to get everything lined back up.
Jun 9, 2010 at 2:06 PM
