2003 Cadillac CTS loud noise coming from front of car when
85,320 MILES • 6 CYL • AWD • AUTOMATIC
JS27CA
I recently took my car to a mechanic (not gm) and had the rack and pinion replaced. About a month or two after, i noticed a loud creaking noise when i turned the wheel, half a turn to the left or right. When i make U-turns, it's very loud and creaking also. My cousin said I might have to bleed the rack and pinon b/c air bubbles, but i'm not sure..any ideas?
Dec 1, 2009 at 1:24 PM
FACTORYJACK
  • 4,159 POSTS
Air in the p.s. system would cause more of a growling. I would lean more toward upper strut bearing, lower ball joint, or control arm(which the ball joint is serviced with). Can you determine if the noise is coming from the left or right? With the aid of a second person, raise the hood and turn the wheels to make the noise while someone touches the affected pieces, that may identify the noise. You didn't specify, does the vehicle have to be moving to make the noise or, will it make it when stationary and turning the wheel?
Dec 1, 2009 at 2:10 PM
