2003 Cadillac CTS Heater not blowing hot air
92,000 MILES • 6 CYL • 2WD • AUTOMATIC
CADILLACPROBLEMS03
I have a 2003 Cadillac cts. I replaced my water pump and thermostat. I still don't have heat. When you first turn on the heat it blows warm for a second then goes cold. Any ideas why it's still blowing cold air?
Oct 10, 2009 at 2:41 PM
FACTORYJACK
  • 4,159 POSTS
If it does blow warm shortly, it could be low flow through the core either by a plugged core or restriction to it. If you can get to the connections and disconnect, you can try compressed air through it. Or if you can determine which line is outlet, disconnect it and when started, check the flow. Your heater control valve should have vacuum at the line when heat is requested.
Oct 14, 2009 at 4:21 PM
