2003 Cadillac CTS drivers door switches dont work
89,000 MILES • 6 CYL • 2WD • AUTOMATIC
CITY28212
none of the door switches work locks,windows,truck,mirrors but the night light do come on..the remote lock will lock and unlock the door
i checked all the fuses,cleaned the contacts took the door apart checked connections
car has been sitting for a year
the battery was replaced a week ago
what could be wrong
Jan 10, 2009 at 2:09 AM
DS38401
This is a long shot, just wondering if you ever solved this and how? I have an '03 with the same issue, happened after a battery replacement, but I also left drivers window open and it rained really hard. Doh!!
Thinking it's the drivers door control module, but looking for any advice I can get.
Thanks.
Jul 5, 2011 at 8:58 AM
CADIEMAN
  • 3,544 POSTS
you have blown fuses check engine, interior or the trunk panels.also check the relay panel under the r/side dash for a bad fuse.
Jul 5, 2011 at 4:17 PM
DS38401
Thanks Cadieman,
I checked and replaced all the fuses labelled as anything to do with the drivers door already, I know that's not the cause.
Was hoping to hear how city28212 fixed his issue.
The drivers door lock will work with the key fob or pass door power switch, but none of the buttons on the actuall driver's door will do anything. The trunk release button is totally seperate from the power window buttons, and the power door lock button is again seperate from the those 2, so I'm thinking it's the control module they all link into.
I might try pulling the door panels and swapping pass and drivers modules if posible.
Jul 6, 2011 at 7:58 AM
CADIEMAN
  • 3,544 POSTS
you need to check the voltage on orange and orange/black wires.voltage on the pink wire with key on.we cant do anything utill you check the voltage.each switch has a power wire.possable a l/f door lock actuator.take the upper door panel lose and spray silicone on the actator.see if it starts locking and unlock.check at the trunk release selinoid gets power when you push the button.poss. a bad selinoid.
Jul 6, 2011 at 11:53 AM
EMSPG
I have the same problem. I changed the DDM not got fixed. All buttons power up as i can see thier lights to be on switches but not working. Please if anyone solve this issue help me.
Dec 19, 2019 at 3:00 PM
STEVE W.
  • 15,393 POSTS
The lighting in the buttons is a different system than the control switches. What is the issue you have and what vehicle?
Dec 23, 2019 at 7:59 AM
