Hi Rasmataz, did what you recommended. Checked fuel pressure - pressure tested OK. No signal to injectors & no spark at all. Engine turns over, but will not start at all now, not even with starting fluid. Could it be crank position sensor ? Is there a way to check CKS ohms resistance if it's off the engine ?
Nov 5, 2009 at 11:30 AM
