My 2003 CTS Cadillac (with 93K km) turn off on traffic light and the shift stuck in parking position as well as key in ignition slot.
I can start the car and turn it off but wasn’t able to change the shift position.
Only solution was to tow the car home.
Since then, I figure out way to release key and to enable shift movement by disconnecting shift solenoid, so I can use the car.
Problem now, I have permanently:
1. “Anti-Theft system†light on
2. “Traction Control†light on
3. Gasoline level indicator does not work
4. There is no light indicator for shift position
Maybe there are more things that do not work but I did not come across yet.
I should mention that car was in garage for the winter and during thet time I kept the battery disconnected.
Apr 22, 2010 at 10:10 AM
