Electrical problem
2003 Cadillac CTS 4 cyl Two Wheel Drive Automatic 120000 kms
Driving today in traffic, my car seemed to act like it was running out of gas. Slowed down, and then stopped. Since I pretty much had a full tank, I knew this was not the issue. I simply turned the car off and then started it again and off I went. This however kept happening within 2 minutes of it happening previously. I noticed as well the battery light had come on some of the times. I pulled into a parking lot, and right before it shut off again it said something like engine pressure low shut of engine. It then shut itself off. During this time as well, the wheel would be very hard to turn and the brake pretty much impossible to press down on. After being in the parking lot a few minutes, I put some oil in, and got myself home. I then put more oil in later in the day. I made it to work, about 10kms away, no issues. Then on the way home about 4hrs later it started happening again when I was on my way up a bit of a hill. Same issues. I again managed to get myself home, but it no longer will turn over easily and takes quite a bit of key turning to start. Battery light is on now as well. I am hoping it’s just the battery? Any help is much appreciated!
Thanks!
Thanks!
Mar 18, 2010 at 12:37 PM
