2003 Cadillac CTS
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
JEFFERISMAN
I have a problem that I back out of the garage and then go into drive and the car just barely moves forward. after moving very slowly it will start to move normally and after surging a little the transmission finally shifts normal than is fine the rest of the day. It only does this the first time in the morning. I took it to a transmission shop and they said they see what it is doing but that it doesnt do it long enough for them to find the problem. They could not find a code on the transmission or the engine. I bought a penn warrenty when I bought this used car but now Im afraid that something is going to happen after the warrenty because no one can find a problem with it.
Jan 11, 2010 at 1:48 AM
ERNEST CLARK
  • 1,730 POSTS
Your transmission is definitly not taking off in first gear. This may be an internal/mechanical issue with the trans, or it may be electrical with the PCM.
If the shop you take it to can't find the problem, go to a cadillac/GM dealer.
Feb 28, 2010 at 2:53 PM
NASCADDY
Jefferisman Im having the same problem... What was the problem please
Mar 30, 2012 at 2:34 PM
