2003 Cadillac CTS
WHITEY35
Heater problem
2003 Cadillac CTS 6 cyl Two Wheel Drive Manual
i have double heaters controls driver & passenger the passenger one works fine the drivers side you can turn it up to 90 degrees and it still blows ice cold air. thanks ryan
Feb 7, 2010 at 2:15 AM
FACTORYJACK
  • 4,159 POSTS
Could be an actuator fault, or default as result of a fault similar. It should have a code stored in the system, unfortunately you will need a scan tool to retrieve it.
Feb 7, 2010 at 4:56 AM
