2003 Cadillac CTS
COLLIARWOODS
2003 Cadillac CTS
When I crank my car, it will not stay crank, and when it crank up it runs rough, so what's my problem with it?
Oct 5, 2010 at 7:03 AM
  • 75,988 POSTS
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Idle air control valve.
May 2, 2017 at 9:25 AM
