2003 Cadillac CTS
BENZCL55
2003 Cadillac CTS 60000 miles
car want start after setting overnite.Don't leave ennything on, have check. have new (start & alternator
Feb 24, 2008 at 10:27 PM
MERLIN2021
  • 17,250 POSTS
What's the symtom? Dead battery? does it crank?
Feb 24, 2008 at 10:28 PM
MERLIN2021
  • 17,250 POSTS
To: merlin2021
Posted: Mon Feb 25, 2008 7:56 am
Subject: car want start
no the car want start, the battery is dead all the way
Answer to PM: you have a parasitic drain, Get an analog voltmeter remove the negative battery cable, attach the Black lead to the battery post, Red lead to cable end, then pull fuses one at a time, make sure there are no accessories or lights in the on position, Key off! Close the door after each fuse and check meter, when you pull the fuse for the bad curcuit, the meter will drop to 1 volt or so. Check all fuses, even under the hood. If meter does not drop, remove the battery connection from the alternator, if it drops now, the diodes are bad in the alternator. Put the fuse back in were it goes as you go so you don't forget which fuse goes were! Mind you GM with onstar are tough to test, it's a matter of waiting for stuff to cycle off, Might want help on this one!
Feb 24, 2008 at 11:00 PM
BUZZSAW
  • 1,198 POSTS
[quote:0fd3d50be1="benzcl55@yahoo.com"]2003 Cadillac CTS 60000 miles
car want start after setting overnite.Don't leave ennything on, have check. have new (start & alternator[/quote:0fd3d50be1]
why was an alt and starter put in? how often is the car driven? How far? what kinda parts did you buy?( where from?)
Feb 25, 2008 at 3:29 AM
