1998 Cadillac Concours wiill not start.
89,000 MILES • V8 • FWD • AUTOMATIC
KENNJ
The car,, when trying to start will display will display a message of "security disabled" "remove key wait 3 minutes." After the 3 minutes time interval the display will indicate "start car." Sometimes, if I'm lucky the car will start, other times after two, three, most I ever waited was four tiimes (12 minutes) the car would restart. Now the vehicle is dead in the garage and will not start at all. The starter does not even engage... the Cadillac dealer that has looked at it twice has no clue and has given huge price quotes on something they seem to know nothing about. I sincerly hope you can provide some direction on this!
Oct 15, 2009 at 1:49 PM
FACTORYJACK
  • 4,159 POSTS
My guess, and highest probability is the ignition lock cylinder. Funny that the dealer can't figure it out, at our dealer they are run-of-the-mill. There is two small white wires that carry the resistance value down the column, and these wires break over time.
Oct 15, 2009 at 3:06 PM
KENNJ
you are exactly right. This is where the problem WAS!
I found a very useful web site explaining how to check and bypass the "VATS" system on this vehicle. The items needed cost just over $10.00 at the local Radio Shack store. After I measured and determined the correct resistance from my ignition key, the total reapair including removiing the the lower dash panel took about one hour.
Thank you for your reply.
Oct 16, 2009 at 1:40 PM
FACTORYJACK
  • 4,159 POSTS
And I'm assuming it starts and runs now. Good work!
Oct 16, 2009 at 2:59 PM
