1996 Cadillac Concours Running hot
100,000 MILES • V8 • FWD • AUTOMATIC
KINGJOHN0
Changed out theromastat, Fans are not working. Where are the fuses or sensors to make the fans operate.
Oct 16, 2010 at 3:44 AM
FACTORYJACK
  • 4,159 POSTS
Do the fans come on with the A/C compressor engaged?, if so the temp sensor may not be showing hot enough to turn the fans on. This is not necessarily a fault with the sensor. Have the cooling system checked for an internal leak, presence of combustion gases.
Oct 16, 2010 at 7:14 AM
