Changed out theromastat, Fans are not working. Where are the fuses or sensors to make the fans operate.
Oct 16, 2010 at 10:44 AM
Repair Safety Notice:
This information is for general instructional purposes only. Vehicle repair can be dangerous.
Verify all information, follow manufacturer service procedures, use proper tools and safety equipment,
and consult a qualified repair shop when needed.
FACTORYJACK
CAR REPAIR CONTRIBUTOR
Do the fans come on with the A/C compressor engaged?, if so the temp sensor may not be showing hot enough to turn the fans on. This is not necessarily a fault with the sensor. Have the cooling system checked for an internal leak, presence of combustion gases.
