1996 Cadillac Concours P0302 Code - Cylinder #2 Misfire
1996 CADILLAC DEVILLE CONCOURS
175,000 MILES • V8 • FWD • AUTOMATIC
BEGEMOTT
Hi. I need help figuring out what needs to be done to fix P0302 Code - Cylinder #2 Misfire. I've replaced all spark plugs & wires. Could it be injector? If so, how do I replace injector?
Apr 21, 2008 at 6:28 AM
BUZZSAW
  • 1,198 POSTS
[quote:30e64ebfef="Begemott"]Engine Performance problem
1996 Cadillac Concours V8 Front Wheel Drive Automatic 175000 miles
Hi. I need help figuring out what needs to be done to fix P0302 Code - Cylinder #2 Misfire. I've replaced all spark plugs & wires. Could it be injector? If so, how do I replace injector?[/quote:30e64ebfef]
loosen up the fuel rail bolts, I believe there are 4 and it attaches to the intake through the intake bolts, and pull it up a little around the #2 Injector, do not brake the rail its plastic
Apr 21, 2008 at 9:02 AM
