1996 Cadillac Concours my car is shaking
1996 CADILLAC DEVILLE CONCOURS
174,200 MILES • V8 • FWD • AUTOMATIC
MWAGNER13
when im driving my car the steering wheel shakes and my car does as well a little...i was just trying to find of what was causing this problem so i could get it fixed and roughly how much it would cost to get it done
Apr 30, 2010 at 1:16 AM
VEGASFARMKID
  • 30 POSTS
visually inspect the tires look closely at the tread area. Look for a lump or bulge. If you find a bulge, you will need to replace the tire. (simple and most inexpensive)
While you are inspecting try and move the tire by hand. Grab the top of the tire and give a good pull, Maybe it will move or "clunk" in such case you may have a bad wheel bearing. In that case you would look at $125 in parts and two hours labor at your local repair shop.
Last: while you are inspecting... try to twist the tire by hand, right to left. If it moves or makes a "clunk" that will get expensive fast. You maybe looking at tie rod ends, front alinement, extreme case steering box or other related componets.
Apr 30, 2010 at 3:38 AM
