1996 Cadillac Concours ENGINE OVERHEATING
PARVOPITS
  • 9 POSTS
Engine Cooling problem
1996 Cadillac Concours V8 Two Wheel Drive Automatic 54K miles
THE ENGINE OVERHEATING DISPLAYS ON DASH AND WARNS TO SHUT OFF ENGINE FOR PROTECTION.
IT HAS OIL AND ANTI-FREEZE, WHAT SHOULD I CHECK TO BE WRONG NEXT??
Mar 7, 2008 at 6:16 AM
  • 75,988 POSTS
For a start you can find the thermostat and replace it then come on back if it continues-
Mar 7, 2008 at 6:26 AM
PARVOPITS
  • 9 POSTS
DESCOVERED IT WAS THE WATER PUMP BELT BROKEN. HOW DO I REPLACE IT? DO THE WATER PUMP OR PULLIES HAVE TO COME OFF?
Mar 7, 2008 at 2:56 PM
PARVOPITS
  • 9 POSTS
Mar 8, 2008 at 2:02 AM
  • 75,988 POSTS
See below
https://images.2carpros.com/forum/automotive_pictures/12900_water_pump_5.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_water_pump_devile_1.jpg
Mar 8, 2008 at 6:24 AM
BUZZSAW
  • 1,198 POSTS
the belt only requires a 13 mm wrench, put it on the pully bolt may have to take off the black protector bracket, but ck the water pump and see if it is seazed up
Mar 10, 2008 at 5:56 AM
