1995 Cadillac Concours Turning
GORILLA614
Noises problem
1995 Cadillac Concours V8 Front Wheel Drive Automatic
Okay.....I have a 95' Cadillac Concourse....V8 Northstar engine in it.....I just need to know why when I turn it makes like a eeeeeeeh noise almost like a noise when u push a romote control car without the batteries......
Aug 6, 2009 at 9:11 AM
FACTORYJACK
  • 4,159 POSTS
Happens when turning both directions? Have you checked your power steering fluid?
Aug 6, 2009 at 2:25 PM
GORILLA614
U know what that was the problem.....streering fluid.....but u think maybe I have a leak somwhere......
Aug 7, 2009 at 9:42 AM
FACTORYJACK
  • 4,159 POSTS
More than likely, it had to go somewhere. A few places are the pressure hose and gear, you might have evidence. A couple other possibilities that may not be readily visible, are the back of the pump leaking into the engine valley, or the gear leaking past the rack seals and the fluid being retained inside the boots.
Aug 7, 2009 at 3:22 PM
