1995 Cadillac Concours Tune up
1995 CADILLAC DEVILLE CONCOURS
DUANE MATHEWS
1995 Cadillac Concours V8 Automatic 212000 miles
How to tune up a The Cadillac Concours
May 20, 2010 at 3:44 PM
Check your engine compression before you do it, its not gonna do you good if its not to par.
May 20, 2010 at 3:49 PM
FACTORYJACK
  • 4,159 POSTS
Not really much you can do for a tune up. Replace the spark plugs and wires, if they are original. Replace the fuel filter, PCV valve, clean the throttle plate, check/replace the air filter, and replace the fuel filter if it has been some time. There is no adjustments or settings that can be made.
