1994 Cadillac Concours blower won't shut off
120,000 MILES • V8 • FWD • AUTOMATIC
SDK561
my blower won't shut off...never shuts off
Feb 16, 2009 at 11:54 AM
MASTERTECHTIM
  • 4,750 POSTS
even with the key off? full speed?
Feb 16, 2009 at 12:00 PM
SDK561
full speed even with the key off....thanks
Feb 16, 2009 at 12:12 PM
SDK561
[quote:2aaf1d7bbc="mastertechtim"]even with the key off? full speed?[/quote:2aaf1d7bbc] please answer....thanks
Feb 19, 2009 at 2:43 AM
MASTERTECHTIM
  • 4,750 POSTS
very sorry for the delay. i just looked at wiring schematic and the blower gets power all the time aqnd the ground is controlled by the heater/ac programmer located on the heater box plenom. although i have never run into this problem before i would assume the programmer is shorted out causing a ground all the time. i would first cut the gray and black wire and see if that shuts off the blower, if it does then replace programmer, if it still stays on replace the blower motor. hope this helps
https://images.2carpros.com/forum/automotive_pictures/139033_no_21.jpg
Feb 20, 2009 at 12:31 PM
