1994 Cadillac Concours bad front seal leak
129,000 MILES • V8 • FWD • AUTOMATIC
GHOSTFLAME57
I just want to check to see if theres a seal of some sort thats inside the trans behind the front seal before I put the trans back in with just replacing the torkconvertor seal. I see no cracks in case. Also can a clogged tranny cooler cause only a front seal leak
Sep 29, 2010 at 12:00 PM
FACTORYJACK
  • 4,159 POSTS
There are seals inside behind the front seal, but they are for internal TCC hydraulic circuits. You would not have an external leak issue with them. There is a seal on the stator support to case(the part that the converter hub seal is installed), a square cut o-ring. It should not be a leak under pressure. I wouldn't suspect a clogged cooler to cause a front seal leak, it should have no noticeable effect on pressure, most noticeable would be signs of transmission overheating.
Sep 29, 2010 at 3:52 PM
