1986 Cadillac Cimarron wont start affter overheat
RCH71159
Engine Mechanical problem
1986 Cadillac Cimarron 6 cyl Two Wheel Drive Automatic
have check oil vaive cover and spark plug also change plugs .no water in oil or valve cover. no water on spark plugs still won't start
Feb 13, 2010 at 8:32 AM
HMAC300
  • 48,601 POSTS
first thing how hot is this car getting? and why? you should check fuel pressure and a few other things in the ignition system like dist cap, coil, pickup coil,etc. If you don't have the stuff to do this then take it to a pro. But fix the overheat problem first as alot of cars overheat and then won't start beacause they are just to hot.
Feb 14, 2010 at 12:06 AM
