when i hit the breaks my break lights wont turn on .. what do i do ???
Jan 27, 2010 at 12:03 PM
BMRFIXIT
✓Experienced Mechanic
Start by checking the fuses
fuse # 12 in the power distribution fuse block
check red wire at the brake light switch should have power
step on the brake and check black/yellow wire it should have power if not switch no good remove and replace
