2001 Cadillac Catera Wont start
2001 CADILLAC CATERA
134,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOSEPH GASTINEAU
After driving car & cooling down engine turns over well but won't start. After several minutes started. Thinking electrical problem. What are your thoughts? Thanks very much.
Joe G. Bellevue,Ne
Dec 6, 2009 at 2:45 PM
Do below and comeback with some results
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Dec 6, 2009 at 3:04 PM
