2001 Cadillac Catera Won't start
2001 CADILLAC CATERA
52,000 MILES • 6 CYL • 2WD • AUTOMATIC
CORNSTALK1
When i drive my catera somewhere and go back to start it an hour or so later it will not start. The car tries to turn over but it sounds like it's not getting fuel, but when I go to start it the next day it starts right up. What could be wrong? A friend of mine says his pickup was doing the same thing and it turned out to be his fuel pump. It's under warrenty but I have a hundred dollar deductible. Would it be worth it for me to fix myself and do you know what the problem could be?
May 17, 2009 at 2:48 PM
Might wanna check the fuel pressure to rule out a failing fuel pump
May 17, 2009 at 4:15 PM
FACTORYJACK
  • 4,159 POSTS
Sounds like a crank sensor that experiences high resistance during hot soak. It is not the easiest to replace, and would be over the $100 deductible. Often times there is a code associated with it, a P0335 in ecm history.
May 19, 2009 at 3:29 PM
