2001 Cadillac Catera Oil Leaks
2001 CADILLAC CATERA
111,000 MILES • 6 CYL • 2WD • AUTOMATIC
INDYLISA
Are there any common oil leaks with this 3.0 engine
Mar 1, 2010 at 12:35 AM
FACTORYJACK
  • 4,159 POSTS
Most common is valve cover gaskets, you will be able to determine that a leak is coming from up high on the engine when viewed from below.
Mar 2, 2010 at 3:38 PM
INDYLISA
Hi guys, Thank you so much! In the mean time we found my leak. The canister oil filter has an o-ring and they left it out when changing the oil.
Mar 3, 2010 at 1:54 AM
