2001 Cadillac Catera misfire # 6
104,000 MILES • 6 CYL • 2WD • AUTOMATIC
OUTLAW60
On my catera #6 cyl. misfires at idle, but when i punch it clears out. When i pull the plug it is wet. I changed the coil packs from one side to the other same thing wet plug. so what do you think the problem is and how to fix. thanks..bob.
Jan 31, 2010 at 9:50 AM
  • 75,988 POSTS
Check the compression and injector for no.6
Jan 31, 2010 at 9:56 AM
OUTLAW60
compression 150
Jan 31, 2010 at 10:08 AM
  • 75,988 POSTS
Plug getting wet might not be firing or the injector is leaking
Engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Jan 31, 2010 at 10:24 AM
