Is it alot of work to change a head gasket on this kind of car? and also if i took it to a garage how much should i pay to have the work done?
Oct 28, 2008 at 1:54 PM
✓Experienced Mechanic
Hi:
Yes, it's a big job. In fact, according to mitehell repair manuals, flat rate is 16 hours labor. It shows the gaskets at 33.99 each and that doesn't includ other gaskets that will need replaced.
If you have any other questions, let me know.
Nov 17, 2008 at 2:42 PM
AUTOTECH3297
MEMBER
[quote:f3bcc3a192="Jacobandnickolas"]Hi:
Yes, it's a big job. In fact, according to mitehell repair manuals, flat rate is 16 hours labor. It shows the gaskets at 33.99 each and that doesn't includ other gaskets that will need replaced. also have been told by dealership you need to drill and helicoil each cyl head bolt hole because thats why they leak they pull threads on engine block
Joe[/quote:f3bcc3a192]
May 26, 2009 at 11:04 AM
FACTORYJACK
Catera don't have problem with head bolts pulling, it is a cast iron block.
May 26, 2009 at 1:34 PM
