MY CHECK ENGINE LIGHT COMES ON WITH THE ABS AND TC LIGHTS, THE CODE IS U2108
May 13, 2010 at 1:34 PM
FACTORYJACK
✓Experienced Mechanic
It looks like a communications fault with the EBCM not communicating for one reason or another. A check of the power and ground at the EBCM is fist step. If there is power and ground at the EBCM, then the communications circuits to the EBCM would be next. If all checks out, then a faulty EBCM would be suspected.
