2000 Cadillac Catera odometer
UTAH11
Transmission problem
2000 Cadillac Catera 6 cyl Two Wheel Drive Automatic
My speedometer went out. At first it would work when the car got started but as of late it no longer works at all i was wondering if it was a wiring problem because i have had a few but they are all resolved and still no odometer how do i go about fixing it
Apr 4, 2009 at 11:19 AM
FACTORYJACK
  • 4,159 POSTS
I believe the speed is given to the IPC from the Brake/Traction module. It is given from one of the wheel speed sensors. Do you have an ABS warning light on by chance? I would say if you don't, you could have a faulty EBTCM, IPC, or wiring in between. The IPC can be tested with a scan tool and a function called gauge sweep test.
Apr 5, 2009 at 4:50 AM
UTAH11
thank you so much this sounds like it is what the problem is. The day the odometer went out the abs and the tcs light both came on and my cruise control went out. Would that happen from what you say the problem might be
thanks again i really really appericiate it
Apr 6, 2009 at 10:31 AM
FACTORYJACK
  • 4,159 POSTS
If you had a wheel speed sensor not sending a signal at all, that could cause it. A faulty brake/traction module, or wiring also. It could be as simple as a wheel speed sensor not plugged in. I think it is right rear that is responsible, but not 100%. You might be advised to have trouble codes read, and perhaps a diagnosis to be sure.
Apr 6, 2009 at 4:31 PM
UTAH11
Thank you so much after hearing what ya had to say the first time i went out and pulled off the drivers side front tire and there on the brake was a little sensor that plugs right in to the brake pad.Well the sensor on that side is broken the wire was just kinda hanging there could this be the problem or should i have the rear one checked as well
Apr 8, 2009 at 3:15 AM
FACTORYJACK
  • 4,159 POSTS
If the wires plug into a brake pad, this is a pad wear sensor. I am not certain if open circuit triggers brake pad wear light, or shorting to ground. What you have if the wires are broken/severed is an open circuit. If you are certain it goes to a brake pad, I would check the rear, and/or have it scanned for codes.
Apr 8, 2009 at 10:02 PM
