2000 Cadillac Catera Dash Lights
143,234 MILES • 6 CYL • 2WD • AUTOMATIC
MARTIN.SPEARS
I was installing a new audio system in my cadillac. While attaching the wiring harness to my new radio the instrument panel no longer lights up. as far as i can tell the wiring to the panel is fine, but yet to find a fuse.
any help would be very greatful
Mar 16, 2010 at 11:19 AM
FACTORYJACK
  • 4,159 POSTS
Do you have any switch lighting either. The fuse that I am showing is fuse 26 in the fuse block, it is labeled CLAMP 58. It supplies power to the dimmer switch, and then all the items that are on the dimming circuit.
Mar 16, 2010 at 4:34 PM
MARTIN.SPEARS
i will check the fuse an see.
thankyou
Mar 16, 2010 at 9:42 PM
