2000 Cadillac Catera car will not start when hot
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
ARMY SGT
2000 cadillac catera i have no problem in the winter but in the summer when its really hot when i shut the car off and run in the store and get back in the car it will not start i have to wait for about 30 to 40 minutes then it will start i replaced the crank sensor could it be the srarter
Jun 22, 2010 at 8:20 AM
  • 75,988 POSTS
Next time it refuses to start-don't wait for nothing-Lets do below for a start to determine if its fuel or spark related issue and get back with some results
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jun 22, 2010 at 7:36 PM
