2000 Cadillac Catera battery/sun roof
GINLB611
Computer problem
2000 Cadillac Catera 6 cyl Wheel Drive Type unknown Automatic 89,000 miles
My battery light keeps coming on. It does turn off after a few minutes. I took it two places to be replaced. Both places said it need a deep charge and did so. The light keeps coming on upon starting and then goes off. It is the original battery. Should I just replace it? Also, my sunroof worked fine last fall. Now it won't open. Could it be the battery does need replaced and upon replacing it, the sunroof would work too? Thanks.
Mar 31, 2008 at 2:22 AM
BUZZSAW
  • 1,198 POSTS
[quote:17ac1c4c61="ginlb611"]Computer problem
My battery light keeps coming on. It does turn off after a few minutes. I took it two places to be replaced. Both places said it need a deep charge and did so. The light keeps coming on upon starting and then goes off. It is the original battery. Should I just replace it? Also, my sunroof worked fine last fall. Now it won't open. Could it be the battery does need replaced and upon replacing it, the sunroof would work too? Thanks.[/quote:17ac1c4c61]
when you have loss of battery, the windows and sunroof need resetting, I believe your owners manual tells you how to do it
Apr 3, 2008 at 6:47 PM
