1999 Cadillac Catera Oil Filter
102,000 MILES • 6 CYL • 2WD • AUTOMATIC
VENABLEBP
This car has a 300 V6 engine with a 2 peice canaster oil filter (dumb) I want to start changing the oil myself.The canister has 2 pieces and an "O" RING (suplied with each new filter) that goes on the top or near the top between the 2 pieces. The top piece or the cap has 4 rings/slots. Which one would the "O" RING go in? The one closest to the end so when you put the pieces together it would form a seal between the two or in the 2nd ring? The problem I have been having is when I would take it to get the oil changed they don't always get it sealed and I end up with an oil leak. So instead of paying $50.00 to get a leak I 'll do it myself.
Feb 26, 2009 at 2:04 AM
VENABLEBP
[quote:d2e06b9437="venablebp"]Engine Mechanical problem
1999 Cadillac Catera 6 cyl Two Wheel Drive Automatic 102000 miles
This car has a 300 V6 engine with a 2 peice canaster oil filter (dumb) I want to start changing the oil myself.The canister has 2 pieces and an "O" RING (suplied with each new filter) that goes on the top or near the top between the 2 pieces. The top piece or the cap has 4 rings/slots. Which one would the "O" RING go in? The one closest to the end so when you put the pieces together it would form a seal between the two or in the 2nd ring? The problem I have been having is when I would take it to get the oil changed they don't always get it sealed and I end up with an oil leak. So instead of paying $50.00 to get a leak I 'll do it myself.[/quote:d2e06b9437]
Feb 26, 2009 at 2:09 AM
FACTORYJACK
  • 4,159 POSTS
The o-ring should go between the threaded area and the drive end.
Feb 26, 2009 at 1:25 PM
