1999 Cadillac Catera Head Gasket
1999 CADILLAC CATERA
92,000 MILES • 6 CYL • 2WD • AUTOMATIC
JSAUNDE7
I was wondering is it normal for the head gaskets to blow on these models since they have cast iron blocks..I'm seeing oil on my top radiator hose and it's started to run hot.
Jun 19, 2009 at 9:09 AM
FACTORYJACK
  • 4,159 POSTS
Oil on the top radiator hose is not necessarily indicative of a head gasket. You also have the engine oil cooler the is in the valley of the engine. The running hot could be several things, cooling fans, thermostat, faulty sending unit, to name a few. If your concerned, have a block test run on the cooling system to test for combustion gases. If you have oil in the cooling system, it should show up in the surge tank as well.
Jun 19, 2009 at 6:10 PM
JSAUNDE7
I thought normally when it runs hot the first 2 min of starting it up it would be a blown head gasket
Jun 21, 2009 at 4:54 AM
